Posted 18 May 2019 - 06:27 PM
Posted 18 May 2019 - 06:45 PM
Are both of the rubber stops still there?http://minispares.co...px|Back to shop
If one is missing the suspension will drop further on one side than the one with the stop in place.
Posted 18 May 2019 - 06:53 PM
Posted 18 May 2019 - 07:10 PM
Both sides have the stops in place, but those are for the top arms. Is there supposed to be a similar stop for the bottoms?
No there isn't a stop for the lower arm but if someone jacked the car up near the lower arm pivot sometimes the subframe is bent near the lower arm preventing it from dropping. I posted the upper stop because if one is missing everything drops further, if they're present it holds it up a little. The way I usually do it is a block of wood under the pad on the jack and lift the hub up.
Posted 18 May 2019 - 07:20 PM
Posted 18 May 2019 - 07:26 PM
The Drive Shaft on the Driver's side is longer and so that restricts how far the hub can drop as the Shaft bottoms out in the window of the subframe.
That's all pretty normal and in fact that you had to lift the top arm to be able to get the ball joint pin out shows that your rubber cones are in good order.
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
