Strange Squeal From Engine..
Best Answer richcrosse , 19 May 2019 - 12:33 PM
vacuum leak ?
around inlet manifold area or carb area , or a pipe off / cracked
I would take fan belt off - just to eliminate alt & water pump - if not that ...
with engine running , a bit of brake cleaner around the manifold does engine note change ?
if it does - there is the problem
best of luck
Good shout - thank you!
I reseated the carbs and tightened them down and its gone, so must have been a loose nut or something.
Thanks all for the quick replies! Go to the full post
Posted 18 May 2019 - 10:29 PM
Car is a '91 with 1380cc twin carb engine.
So I've recently finished a load of work on my mini, replacing the fuel pump and a few of the rubber fuel lines, I also rebuilt the entire clutch hydraulic system from wok to pedal.
The car has been off the road since December and after finishing the above work I started it for the first time today and it's developed a very strange squealing noise.
It sounds like belt slip, but I checked the fan belt and that seemed fine. Also it sounds like it's coming from the back of the engine, around the carbs/bulkhead area. Could I have done something wrong when I installed the fuel pump perhaps? It's a 1275 mechanical pump.
I uploaded a video of the engine running with the sound to YouTube if it helps - https://youtu.be/ORhZw2SaRfA
Any thoughts?
Posted 18 May 2019 - 11:56 PM
vacuum leak ?
best of luck
Posted 19 May 2019 - 09:26 AM
It sounds bearing-ish to me.
I would investigate the alternator.
Good luck
Posted 19 May 2019 - 11:39 AM
Posted 19 May 2019 - 12:33 PM Best Answer
vacuum leak ?
best of luck
Posted 20 May 2019 - 05:20 PM
thanks for the update -
it's good to know what it was
It don't take much for a leak to start in that area
