Catalytic Converter Bolt Sheared
4 replies to this topic
#1 victorludorum
victorludorum
  • 102 posts
Posted 19 May 2019 - 09:27 AM
I was fitting a new RC40 silencer and connecting pipe, and while one of the bolts on the cat came off fairly easily, the other one sheared. I heated and whacked it, but all to no avail, so I resorted to drilling it out, which has been a nightmare. I've managed to make a 6mm hole through the centre, and I've removed a lot of the flange with a grinding tool on a dremel, but my drill bits are now pretty dull, and the grinding stone has all gone. I don't know what metal this thing is made of, but it's a tough old bastard. For the meantime i've put a 6mm bolt through, which will work temporarily, but I want to get the rest of the old bolt out soon, so that I can replace it with a proper 10mm one.
Does anyone have any magic ideas before i buy another grinding disc?
#2 Shep76S
Shep76S
  • 541 posts
  • Local Club: L&SMOC
Posted 19 May 2019 - 03:54 PM
I just cut an old one flush with a slitting disc and drilled through, fitting a nut and bolt. Maybe I had better drill bits.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 19 May 2019 - 05:40 PM
take it a garage or fabrication shop get em burn a hole through it ……...
#4 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 19 May 2019 - 05:41 PM
A carbide burr would do the job, fitted in a die grinder if you have one.
#5 victorludorum
victorludorum
  • 102 posts
Posted 19 May 2019 - 06:06 PM
What drill bits do you use? I bought the cobalt HSS ones, but they haven't done the job.
