Just sorting out another leak.
There is quite a lot of oil coming from my drivers side inner pot joint. I've replaced the seal but that didn't solve the problem. I've wiggled the Pot joint and it does move. I've read up about changing the diff bush on the diff end housing however my car is an automatic so I cant see a diff end housing.
Any advice would be much appreciated.
thanks
