Oil Leak By Pot Joint
9 replies to this topic
#1 JCmini
JCmini
  • 146 posts
Posted 19 May 2019 - 11:45 AM
Just sorting out another leak.
There is quite a lot of oil coming from my drivers side inner pot joint. I've replaced the seal but that didn't solve the problem. I've wiggled the Pot joint and it does move. I've read up about changing the diff bush on the diff end housing however  my car is an automatic so I cant see a diff end housing.
Any advice would be much appreciated.
thanks
#2 Tupers
Tupers
  • 4,105 posts
Posted 19 May 2019 - 03:18 PM
You’ve definitely got end covers but they’re probably covered in a thick layer of gunk. Get in there with a stiff brush and some degreaser and you’ll soon see the bolts that hold them on.
You can see them in the bottom right of this parts page on Somerfords website. http://www.somerford...age=page&id=156
#3 richmondclassicsnorthwales
  • 942 posts
Posted 19 May 2019 - 07:20 PM
Hi
If you have not done these - https://www.richmond...pid=4&id=730674
Chances are these will be the problem. These just don't fit early early autos, but will be fine for you
Edited by richmondclassicsnorthwales, 19 May 2019 - 07:25 PM.
#4 JCmini
JCmini
  • 146 posts
Posted 20 May 2019 - 09:49 AM
hi thanks.
yes i have replaced those seals but the leak still there. i will have another look later for the end covers
#5 JCmini
JCmini
  • 146 posts
Posted 28 May 2019 - 11:02 AM
So had another look but still cant see the end covers. Am I being thick?
This is the off side drivers side
This is the near side which I kind of see an end cover where the two bolts go through the red part. I'm gussing there are more bolts above the pot joint
Edited by JCmini, 28 May 2019 - 11:03 AM.
#6 nicklouse
  • 17,945 posts
Posted 28 May 2019 - 11:14 AM
ahhhh you have an Auto.
#7 nicklouse
  • 17,945 posts
Posted 28 May 2019 - 12:28 PM
yep only one end cover on the auto.
#8 JCmini
JCmini
  • 146 posts
Posted 29 May 2019 - 08:44 PM
So how do I stop the leak on the drivers side?
#9 Tupers
Tupers
  • 4,105 posts
Posted 29 May 2019 - 09:07 PM
There will be a bronze bush on the RH output of the gearbox but you really need to get a automatic gearbox workshop manual to figure out exactly how it’s replaced.
It’d be worth sending Guess Works a message as he may be able to supply you with the bush in its retainer machined to size and ready to swap in.
http://www.guess-works.com/
#10 nicklouse
  • 17,945 posts
Posted 29 May 2019 - 11:14 PM
Engine out job though.
