Problem With Front Teardrop Mounts
Posted 19 May 2019 - 08:20 PM
Posted 19 May 2019 - 08:48 PM
slacken off the rear mounts and unto the top ones a turn or two.
Posted 19 May 2019 - 08:49 PM
Posted 19 May 2019 - 09:00 PM
You tried Jacking it up under the back of the subframe to take the weight?
Whereabouts exactly should I try this?
Posted 20 May 2019 - 02:44 PM
I just did it. loosen the mount on the back of the subframe - do not take it off. Then support the front of the subframe with a second jack slightly until the hole is right. I had to lift the body a little bit in front the get the holes lined up correctly.
Edited by Alpenflitzer, 20 May 2019 - 02:45 PM.
Posted 21 May 2019 - 07:13 PM
Posted 22 May 2019 - 03:28 PM
Correctly. There are 2 Bolts which you should loosen a little bit. Do not take off. If the hole of the front panel is lower than the hole in the subframe take a strong piece of wood, put it under the two license plate holders and slowly and carefully lift it up until the holes meet.
I did it this way and it worked fine.
Edited by Alpenflitzer, 22 May 2019 - 03:33 PM.
Posted 22 May 2019 - 04:43 PM
Edited by 1314cc, 22 May 2019 - 05:42 PM.
