Edited by Benito_S6, 20 May 2019 - 08:46 AM.
Idle Keeps Increasing
Posted 20 May 2019 - 08:45 AM
Posted 20 May 2019 - 09:02 AM
It's likely to be a worn throttle spindle and/or throttle spindle bushes.
Posted 20 May 2019 - 09:37 AM
thanks for getting back to me, is there a way to check for sure that thats the issue and what’s it like replacing them.It's likely to be a worn throttle spindle and/or throttle spindle bushes.
Edited by Benito_S6, 20 May 2019 - 09:55 AM.
Posted 20 May 2019 - 10:04 AM
Is there any obvious movement up and down of the spindle? Even if there isn't there can still be enough wear to allow air in. Try spraying WD40 or carb cleaner or the like around the bushes with the engine running and note any changes in idle speed.
As for replacement, it's probably worth trying the spindle first as it's easy to replace and sometimes all that's needed. If the bushes need replacing then I refer you to these other threads with people more knowledgeable than I commenting in:
http://www.theminifo...ng-replacement/
http://www.theminifo...spindle-bushes/
Posted 20 May 2019 - 10:09 AM
nice one thanks a lot, I will check for play when I get home and see what I can find. Thanks for your helpIs there any obvious movement up and down of the spindle? Even if there isn't there can still be enough wear to allow air in. Try spraying WD40 or carb cleaner or the like around the bushes with the engine running and note any changes in idle speed.
Posted 20 May 2019 - 04:02 PM
Posted 20 May 2019 - 04:57 PM
Posted 20 May 2019 - 06:31 PM
Try the return spring / s -Again, an over looked item
Main pull back spring from carb to exhaust clamp / abutement plate. Return spring on the side of the carb ?
Also, is the choke dropping down / jet / likely to increase fuel input ?
Ideas for the pot !
Edited by richmondclassicsnorthwales, 20 May 2019 - 06:33 PM.
Posted 20 May 2019 - 06:46 PM
Edited by Benito_S6, 20 May 2019 - 06:50 PM.
Posted 20 May 2019 - 06:53 PM
Any sign of burning oil? Just thinking in theory could be burning some oil once hot enough
Posted 20 May 2019 - 06:58 PM
no oils been on max on dipstick for few months. Check it every week. Also idle sticks high when engines cold aswellAny sign of burning oil? Just thinking in theory could be burning some oil once hot enough
Posted 20 May 2019 - 07:04 PM
Ah well all the best then, mine did it sunday was in a line up at a mini rally and sounded like i had the choke out. Tried blipping the throttle but nothing. Hasnt done it since however.
Posted 21 May 2019 - 03:01 AM
Posted 21 May 2019 - 03:02 AM
