Clutch Strap Vs Clutch Houseing = ?
5 replies to this topic
#1 phillrulz
phillrulz
  • 617 posts
Posted 21 May 2019 - 07:55 PM
Well the answer is lots of aluminium glitter.....
This is what happens when you drive ~150 miles on a clutch with only 2 straps. Hoping this is my problem. Friday took it for a blast think i over reved it and clutched her a bang and gained a vibration. Vibration was mainly noticeable at low engine RPMs on idle it was near normal , on choke / slight throttle she'd vibrate like f***..... When in high revs ( no rev counter) she ran normal no vibration or im guessing so high frequency i couldn't feel it.
Do you guys agree it seems like this was causing my vibration...
If i said the "fly"wheel nearly shooting through the wing didnt catch my by surprise id be lying..... I even knew it was gonna happen . Had a 24" bar on it.
Ps my flywheel nearly went through the wing it exploded with so much force hahaha.
#2 phillrulz
phillrulz
  • 617 posts
Posted 21 May 2019 - 07:58 PM
Anyone have any input which minispares clutch i should go for, 180mm need clutch and pressure plate. Verto.
Im thinking "
CLUTCH KIT TURBO AP WITH 180mm PLATE"- GCK371AF
Or
CLUTCH KIT 3 PIECE VERTO 180MM PLATE UPTO 1990 GCK151MS
#3 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 21 May 2019 - 08:06 PM
Im thinking "
Or
A standard turbo clutch should be more than enough for a 998. :shades:  over 120bhp is where clutch selection seems to get 'interesting'. :/ I would choose GCK151MS. The only difference is a genuine AP clutch plate or a cheaper version, from what I can see.
#4 phillrulz
phillrulz
  • 617 posts
Posted 21 May 2019 - 08:16 PM
Im thinking "
Or
So you say the cheaper one GCK151MS
#5 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 21 May 2019 - 08:27 PM
Im thinking "
Or
The turbo kit should have a slightly stronger diaphragm. I don't think either is a bad choice to be honest. I would definitely buy a new flywheel and get the lot balanced. I think MED quoted me around £40.
#6 phillrulz
phillrulz
  • 617 posts
Posted 25 May 2019 - 03:23 PM
New clutch in and runs like a treat. No vibration.
