Rear Quarter Alignment Issues
13 replies to this topic
#1 Mito
Mito
  • 384 posts
Posted 24 May 2019 - 06:52 PM
I'm having some problems trying to get the rear quarter panel to line up properly with the outer sill and the boot floor.
The outer sill was slightly too high just after the bend and I've had to knock it down a bit to get it to fit something like. I also seem to recall that the closing plate between the heel board and the rear arch should overlap slightly at either the wheel arch or outer sill flange and as it is currently fitted there is quite a sizeable gap between the end of the closing plate and the outer sill. Hopefully you can see this in the pictures below.
The floor, boot floor, and rear arch have all been replaced. The rear panel has also been repaired at the bottom and it didn't line up very well with the old rear quarter that had been repaired. Which is why i've been focusing on trying to line it up with the waist rail, B-post, and top 2 3rds of the rear panel, as I figure these should be reliable.
Attached File  IMG_20190524_172604.jpg   35.84K   5 downloads
Gap between sill and closing panel flanges.
Attached File  IMG_20190524_172550.jpg   42.73K   2 downloads
Closing panel to rear arch
Attached File  IMG_20190524_172535.jpg   46.28K   7 downloads
Boot floor to rear quarter
Attached File  IMG_20190524_172616.jpg   49.57K   7 downloads
Top left of the rear quarter - needs some work but more concerned about the bottom.
Attached File  IMG_20190524_172629.jpg   43.57K   3 downloads
Not sure if this needs to go down slightly to match the rear panel.
Attached File  IMG_20190524_172639.jpg   47.73K   1 downloads
The gap between the rear quarter and door step seems too large?
Attached File  IMG_20190524_172653.jpg   54.04K   1 downloads
Not too bad but probably wants to go up slightly
Attached File  IMG_20190524_172708.jpg   69.2K   1 downloads
Full rear quarter panel
The top of the rear quarter is almost perfectly in line with the rail running between the rear seat panel and B post.
My thinking at the minute is that the rear arch wants to be turned slight clockwise so that the boot floor lines up with the bottom of the rear quarter. The closing panel between the rear arch and heel board can then be shifted further round as well to close the gap between the outer sill and itself.
Does that sound about right?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,897 posts
  • Name: Neil
Posted 24 May 2019 - 07:09 PM
Lots of clamps needed. Pull the rear down with a couple of pair of mole grips.
You may have to dress the inner wheel arch lip as well. Looking at everything it just needs some tweaking here and there. They never just go in without some work.
The B post needs to be dressed back on the door shut. The back of it where it forms part of the window cutout, you may have to slit it and tweak back slightly.
Is the panel Magnum or Heritage.
#3 Mito
Mito
  • 384 posts
Posted 24 May 2019 - 08:19 PM
They're all heritage panels.
#4 sonikk4
sonikk4
  • 15,897 posts
  • Name: Neil
Posted 24 May 2019 - 08:53 PM
As i said that will all go, it just needs a ton of clamps to move things around and dressing of various flanges. It will go just be patient with it. The B post will take some work but i have seen far worse.
I had similar issues with my Heritage panels but some light panel beatings and tweaking got them all in the right place.
The Magnum panel i fitted on my mates Cooper was a pain, the B post was a swine and took a lot of cutting slitting and dressing to get a good tight fit.
#5 Mito
Mito
  • 384 posts
Posted 24 May 2019 - 09:23 PM
Do you mean where the panel wraps around? I have removed all remnants of the old panel from it.
it won't take much i think it is only about a 1-2mm out.
#6 Mito
Mito
  • 384 posts
Posted 25 May 2019 - 01:16 PM
It's getting there. I've knocked the edge of the wheel arch down and used mole grips on the rear end to bring it down a bit.
Attached File  1558789979176-550657.jpg   44.19K   0 downloads
Attached File  15587900129151986863261.jpg   54.31K   0 downloads
Not to far off now.
#7 sonikk4
sonikk4
  • 15,897 posts
  • Name: Neil
Posted 25 May 2019 - 02:24 PM
Yes i meant where the panel wraps around the post. Its the panel i mean for the dressing back with a panel beating hammer, not the actual B post itself.
#8 sonikk4
sonikk4
  • 15,897 posts
  • Name: Neil
Posted 25 May 2019 - 02:30 PM
 eecd2ff22ceffc6b23240210aa51b7d8ba756ff8
And this is a Magnum panel fit at the B post, before
#9 sonikk4
sonikk4
  • 15,897 posts
  • Name: Neil
Posted 25 May 2019 - 02:31 PM
During,
5099e7e18628918df99340b21dc7d0a9a7055e8b
#10 sonikk4
sonikk4
  • 15,897 posts
  • Name: Neil
Posted 25 May 2019 - 02:32 PM
And after, i had to sort out where i had cut the old panel away and the poor cut that was part of the new panel
9468ec3d23bcd8fa9a736237a7c4ccc35e36a75d
#11 Mito
Mito
  • 384 posts
Posted 26 May 2019 - 07:48 PM
Thanks very helpful.
I'm also trying to line up the rear bin and it doesn't appear to line up properly with the contour of the rear of the door step. Is a rear bin from a later model but I wouldn't have thought the door steps were different.Attached File  1558899849915429023854.jpg   39.05K   0 downloads
Attached File  1558899919881627190028.jpg   50.94K   0 downloads
Whilst it's not yet fully down to the floor, there isn't enough downwards travel left for it to fully line up. I'm planning to just took it back but just seems a bit odd that a heritage panel can be so far out. Which always makes me question what I've done so far.
#12 sonikk4
sonikk4
  • 15,897 posts
  • Name: Neil
Posted 26 May 2019 - 08:06 PM
Unless i have reused an original bin there is always an overlap of metal in the corner area.
I had issues with M Machines bins as well and took a lot of tweaking, beating and re profiling to get them to sit right.
The heritage bin i fitted on my lads car took some tweaking around to fit well. You must remember their presses and forms are not that crisp anymore so a lot of their do yake some work to fit spot on.
Trim it back, tweak the bottom return where required and it will go.
#13 Mito
Mito
  • 384 posts
Posted 27 May 2019 - 02:01 PM
Okay, so I've got it to the point now were I'm happy enough to start welding in the rear bin and closing panel + the sill stiffener.
#14 sonikk4
sonikk4
  • 15,897 posts
  • Name: Neil
Posted 27 May 2019 - 06:04 PM
That looks fine so happy days. As i said it just takes time and a bit of tweaking here and there.
There is only so much you can do, old car new panels, things have moved slightly over time, panel moulds and presses getting old. So it all adds up to more time being spent on getting things right.
