Smiths Rvc1004-00Cb
1 reply to this topic
#1 dotmatrix
dotmatrix
  • 390 posts
Posted 25 May 2019 - 10:59 PM
Hello everyone.
I have read several old threads about Smiths electronic tachometers, but not found one that described my problem.
I am trying to install this tachometer http://www.minispare...er/SIB122.aspx which is a Smiths RVC1004-00CB.
What happens is that it does not flick from 0 to 10000 rpm as I read that some does. should it?
Instead it stays on 0 until the engine is started. when the engine runs it works for 5-10 seconds. in this period it seems to be working perfectly.
after this the needle drops quickly to 0 and the needle starts to bounce from 0-800 rpm and back quickly about every 5 seconds.
it does this regardless of which of the two trigger wires I use.
does any of you have an idea what is wrong?
thanks in advace
Martin.
#2 dotmatrix
dotmatrix
  • 390 posts
Posted 26 May 2019 - 08:40 PM
I figured it out. the problem was that I was taking the positive voltage for the rev counter off the smiths voltage regulator, and after having read how that works I can see why it was behaving eradically :D only use the smiths br1303/20 for analogue instruments is the conclusion.
