Mainshaft Big Nut
Posted 26 May 2019 - 06:11 AM
Posted 26 May 2019 - 06:24 AM
Edited by imack, 26 May 2019 - 06:27 AM.
Posted 26 May 2019 - 06:45 AM
As above, ratchets aren't meant to be used like that. I would have thought a rattle gun would be alright unless somebody knows otherwise. Don't do it back up with one as you don't know how much torque is being applied.
Posted 26 May 2019 - 07:14 AM
Posted 26 May 2019 - 08:37 AM
How are you holding it? I just use a 1 1/2 or 2 foot long breaker bar, If you don't have one it's worth getting one, it gets used more than you'd think.
Posted 26 May 2019 - 08:43 AM
Posted 26 May 2019 - 10:34 AM
Could try using a sliding 'T' handle breaker bar (Often come with socket sets as well as a ratchet) and give it a wallop with a copper & hide mallet. Not that I'm advocating hitting tools generally but the 'shock' element sometimes shifts what a long breaker can't move. Ideally you want to be using a black impact series socket as Chrome Vanadium have a tendency to crack when subjected to shock. There is always a risk if the gearset bearings are really worm that a geartooth might break somewhere as the teeth are not meshing evenly but this could also happen with a breaker bar so it's a risk whatever. No matter what though it's crucial the box is held down firmly or you will loose energy if it moves. Personally I put the box face down on a sheet of hardboard and then manoeuvre a railway sleeper size length of timber level on top of it, which I then stand or sit on before going into action. A long breaker bar usually shifts them but have heard others resorting to using an angle grinder but you are also likely to loose the pinion in the process (and the mainshaft, if you are not careful) so best avoided...
Posted 26 May 2019 - 12:21 PM
This is how I have done it. If your work bench is sturdy enough, turn the box upside down and bolt it down through two pre drilled holes in the bench top, then I have a piece of 6" x 2" timber with a hole drilled through it that the extension bar will go through this sits on end on the work bench top and acts as a support for the extension bar and also keeps the socket square on the nut. Attach either a sliding tee with an extension tube or long breaker bar. I have found this method works well as you have both hands available to grasp the tube/breaker bar without having to worry about the socket slipping off.
Posted 26 May 2019 - 04:13 PM
Halfords Advanced Breaker Bar Drive https://g.co/kgs/zEDe6e
Also you need to have the gearbox locked in 1st and 4th as this combination minimised breaking teeth off
Posted 26 May 2019 - 05:54 PM
Posted 26 May 2019 - 07:35 PM
Sorry, is this the flywheel bolt ? I have the verto 30mm one and got it off with a 18" bar from halfords. Wasnt too bad.
Posted 26 May 2019 - 07:41 PM
No it's the mainshaft nut which holds the diff pinion on.
Sweet, ignore me then
Posted 27 May 2019 - 07:51 AM
Posted 27 May 2019 - 08:46 AM
Are you in Wellington Herefordshire ?
