Thermostat Gaskets
21 replies to this topic
#16 victorludorum
victorludorum
  • 102 posts
Posted 29 May 2019 - 06:29 AM
Use a thin bead of Loctite Blue (5926) gasket sealant on both sides of the gasket including round the stud holes, the thin version will work fine.
Did this, but it didn't work, so maybe there's more to the problem than just a gasket. These thickers ones will be the last throw of the dice before I consider something else.
#17 brivinci
brivinci
  • 1,104 posts
Posted 31 May 2019 - 12:41 AM
What are your thoughts (anyone) on the original type the Spares sell. They are black on one side, red on the other. I have been running them whenever needed but always interested in THE BEST solutions.
Certainly not all gaskets are created equal. I try and buy only gen-spec gaskets and its seemed to be a good plan so far. I only recently got a leak from the timing side...for the first time AND after multiple rebuilds. One of the few Minis that didnt leave its mark everywhere. Used the Rover timing cover gaskets with the dry "sealant" stuff built right onto the gasket. Did me right until recently but that would be an out of shape cover I suspect.
#18 imack
imack
  • 1,873 posts
Posted 31 May 2019 - 04:40 AM
Those are the gaskets that leaked for me. Only 0.4mm thick, maybe ok if the top surface of the head has been skimmed and you're using a billet alloy thermostat housing but I couldn't get them to seal.
Never had an issue previously or since with the 1.6mm thick blue gaskets from minispares or other sellers. Cork ones are ok too but keep squidging out the side of the housing.
#19 brivinci
brivinci
  • 1,104 posts
Posted 31 May 2019 - 08:21 PM
Good to know. I'll order a set of the blues to have on hand
#20 kommander
kommander
  • 210 posts
Posted 13 July 2019 - 02:12 PM
Is gasket sealant necessary with the blue gaskets?
#21 imack
imack
  • 1,873 posts
Posted 13 July 2019 - 04:00 PM
I don't use sealant on them
#22 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 13 July 2019 - 04:27 PM
I also like the blue gaskets from MiniSpares, they work a treat - no sealer needed. But - if you think you may have to have it back off again, I put  a layer of grease on the head side - lets you use it again.
