Floor Crossmember - Heritage Or Not?
Posted 03 June 2019 - 07:42 PM
Since joining I have found this forum very useful but I haven’t come across an answer for the above title.
I’m looking at replacing my crossmember but will attempt one side at a time - I was inclined to order the full panel and cut into two.
Would you recommend a heritage panel for this or will a magnum or similar suffice? If anyone has any pictures or tips that would help with my build I’d very much appreciate them.
Thanks in advance.
Posted 03 June 2019 - 07:50 PM
"I’m looking at replacing my crossmember but will attempt one side at a time - I was inclined to order the full panel and cut into two."
I would really try and avoid doing this if you can, changing it in one piece will give much better and stronger result.
Posted 03 June 2019 - 07:55 PM
Thanks for the swift reply. The reason I will be doing this is due to the other panels I need to change. I may decide once I have the floor, inner & outer sills welded in I will look to change the piece in full. I’m currently attempting the right hand side of the car first as this is by far worse than the left hand side.
Posted 03 June 2019 - 08:53 PM
Posted 03 June 2019 - 09:06 PM
Would a heritage panel be a better fit or is a magnum or Non-genuine panel suffice for this?
Posted 03 June 2019 - 09:58 PM
Posted 04 June 2019 - 06:53 AM
Yes it's more expensive, but you will save sooooo much time and effort. Wish I had done that.
Posted 04 June 2019 - 07:57 AM
Posted 04 June 2019 - 08:10 AM
well, do have a good poke around if you havent already, it often ( ususally) is a lot worse than it looks.
Posted 04 June 2019 - 08:18 AM
Haha I know this only too well!
