Changing A Choke Spring
Benito_S6
, Jun 06 2019 02:45 PM
3 replies to this topic
Posted 06 June 2019 - 02:45 PM
How do I refit the choke spring and linkage together. Took photos but not sure where I’m going wrong. Seen a few things that say the other end of it should go where I’ve put that arrow. Anyone done it and what’s the best/easiest way.
Posted 06 June 2019 - 02:57 PM
As i don’t know how to delete topics I’ll just add this incase someone stumbles on this. Hopefully it helps. As far as I can work out the choke assembly sits like this (first pic) while off the car. Then you need to pull the cam round and attach the choke cable and trunnion. How I did it was put the pinch bolt through loosely. Then get the end of the spring in the indent and wind it anti clockwise. Then hook the rod from the float through and tighten the bolt.
Edited by Benito_S6, 06 June 2019 - 09:34 PM.
Posted 06 June 2019 - 09:34 PM
I seem to remember those springs being a pain to attach when I built my HS2's
Posted 06 June 2019 - 09:37 PM
so fiddly. Wish I had just taken carb off in first place. Tried doing whilst still on car but absolute nightmare to do and work out. Hopefully this thread is helpful to someoneI seem to remember those springs being a pain to attach when I built my HS2's
