Project Mod Or Not To Mods
gem1
, Jun 07 2019 04:46 PM
13 replies to this topic
Posted 07 June 2019 - 04:46 PM
Here it is mini city 850 frm a membdr here
Posted 07 June 2019 - 04:55 PM
Looks like a great starting point. What plans are you thinking?
Posted 07 June 2019 - 05:27 PM
So far to be mint would need both inner wings
The d/s pillar still solid but pitted badl
Outer floor edge to first flute it has orignal cills but the floor is badly pitted inwthat areaouter cills and half boot floor and also the front floor or part of
I really cant decide between standard (its all there) or modify on a largely untamperf with car i love the colour to
Edited by gem1, 07 June 2019 - 06:03 PM.
Posted 07 June 2019 - 05:33 PM
Start with standard maybe and modify what you want to in the future.
Posted 07 June 2019 - 05:49 PM
Yes thats where its headed get the body mint and solid and then go from there it has been under a tarpaulin 10 years outside the last owner went to south africa and gave it to this guy (who had a mini ) it was still motd and driving the car run out of mot and a few bits were taken of really daft bits a spark plug a spring ect.
With being under a tarp that length of time with a spark plug out the engine is seized it has 70k miles on it if keeping totally standard we would rebgduild it but more bhp ip always nice
Edited by gem1, 07 June 2019 - 06:02 PM.
Posted 07 June 2019 - 06:10 PM
Pis of random areas
Posted 07 June 2019 - 08:43 PM
The worst bits
Posted 07 June 2019 - 08:48 PM
Are you going to do it all yourself? I think keep it semi standard I.e change from original with things that you can reverse like wheels and interior.
Posted 07 June 2019 - 09:15 PM
Yes its going to be built by ourselves
Posted 13 June 2019 - 12:55 PM
So thats complete bulkhead along with both inner wings ordered and also the full windscreen surround panel
At least with a completely new front end /bulkhead we should be good for many many years
Edited by gem1, 13 June 2019 - 01:06 PM.
Posted 13 June 2019 - 01:11 PM
So if we weld a plate to box sebtion that bolts to the subframe mounting on the toe board and that welds to the bracgng in the door frame and across to each a post that should make sure it goes back where it should yes ??
Posted 13 June 2019 - 09:56 PM
This is what we are aiming for this is 1 of endafs but this is what we have settled on
Posted 23 June 2019 - 11:21 PM
So inner wings changed and full bulkhead panel offered up it appears that the drivers side inner wing appears to be around 10_15 mm to long the pillar holes are lined up the shock mount to x member ard lined up but where the lip of the inner wing is it sits way low seems ok passenger side x member level to bulkhead x member all braced ect have i just got a bad panel(inner wing) or is the toeboard$bukhead panel twisted in transit
Posted 23 June 2019 - 11:31 PM
So either
The toe board is meant to be completely straight and flat its full width or its got a slight taper upwards on the ends where it meets the inner wings
If i
So either we need to fetch the toe board down at the end to meet the inner wing return or we need to trim the lower of the inner wing to suit just trying towfind out wether its meant towbe flat or not
If i
