Padded Dashboard Tops
3 replies to this topic
#1 Rallye67
Rallye67
  • 19 posts
Posted 08 June 2019 - 03:35 PM
hi , got a bit of tiding up to do as you can see , is it possible to take dashboard top off without removing windscreen ?
Also fresh air hose that goes front grill should it have a foam liner ? mine looks like it had but think there's been a mouse in there !
Lastly   the o/s hose is missing , looks like it goes out to inner wheel arch is this right ?
Edited by Rallye67, 08 June 2019 - 03:39 PM.
#2 1314cc
1314cc
  • 168 posts
  • Local Club: tumbleweedminisbristol
Posted 08 June 2019 - 05:29 PM
3 nuts holding the top dash rail,one in the middle and one either end. Once undone it will need a wiggle and maybe a whack to remove!
#3 cal844
cal844
  • 6,413 posts
  • Local Club: www.scottishmini.net
Posted 09 June 2019 - 09:48 PM
And a huge risk of the dash not lining up as it should to bolt back on.
There should be 2 fresh air intake pipes, the drivers side should have a box under the wing to connect the 3 way pipes. Then the passenger side is straight to the cabin.
Your car will rot here so be prepared to wash the areas regularly.
Personally we remove the fresh air intake and weld the holes closed but then need to run the car with a window open in winter..
If you do decide to weld them up use a good non silicone sealant to ensure the welding is protected as well as possible.
#4 Rallye67
Rallye67
  • 19 posts
Posted 16 June 2019 - 12:14 PM
right got the nuts off , well 2 sheared   how do you get the top rail out with the thread in the middle still there ? tried pushing it up but  wont work  , I presume the windscreen vents stay where they are ?
crap picture included.
Mini Spares
