Mini 1293 Cc Track Day Car Missfire On Two Cylinders
2 replies to this topic
#1 ducatibip916
ducatibip916
    Starting My Mini Up
  • 1 posts
Posted 08 June 2019 - 07:12 PM
hi, first ever post so be gentle, help to cure a missfire
just rebuilt my 1990 mini cooper engine with  new pistons/ rings to 1293cc ,45 dcoe medium length race manifold  with modified bulkhead ,kent high lift cam 286, with adjustable vernier ,new coil . aldon distributor, race with no vac.new leads ,plugs  ,ported big valve head , race fuel tank with fuel reg ,surge tank, and twin fuel pumps
my problem is on cylinder 1 and 4 when you remove the plug leads  it makes no difference ,carried out a compression test and these are 180 psi   . 3 and 4  200psi, carried out a leak check  no real loss any cylinder, spark ok,
please help !!
#2 Rob7620
Rob7620
  • 19 posts
Posted 08 June 2019 - 08:59 PM
Have you tried swapping them or trying new leads and plugs?
#3 nicklouse
  • 17,945 posts
Posted 08 June 2019 - 09:09 PM
is the miss at all times or just tickover?
i would expect higher compression readings for a fresh engine as well.
