I may need to replace the tie rod bushes, having a poke around pre-mot and noticed the soft rubber inner bush is really squashed up and distorted. I dont even know if this is an MOT issue but looks a bit dodgy. I have the MiniSpares hard poly / rubber kit with the uprated rods.
Question is, I had the suspension and camber/castor etc set up some time back (its probably due it again) by replacing the bushes if needed will this throw anything out? Perhaps by the inner rubber bush already being so compressed its now out anyway?
Both sides are pretty much the same. The outer purple harder one appears to be ok.
