Edited by croc7, 11 June 2019 - 05:54 AM.
Starter Spring Question
croc7
, Jun 11 2019 05:38 AM
3 replies to this topic
Posted 11 June 2019 - 05:38 AM
How much axial play of the bendix spring/washers assembly, at rest, along the armature shaft would you be comfortable with? I’ve got about .1” and it spins freely; my starter-r-r-r guy says it’s fine.
Posted 11 June 2019 - 07:20 AM
as long as it cant hit the ring gear it is fine.
Posted 11 June 2019 - 05:14 PM
Its not the small inner spring that controls movement of the gear assembly, its the large bulky one at the end of the armature shaft. The other starters that I've looked at have no slop in the spring at all.
Edited by croc7, 11 June 2019 - 05:27 PM.
Posted 13 June 2019 - 11:53 PM
Found the problem. The circlip holding the bendix spring/washer assembly on the end of the armature shaft had broken and allowed it to migrate on the shaft. Don't know how long it would have stayed in place before letting go.
