Coolant Hose Help
Posted 13 June 2019 - 06:38 AM
Where does the sandwich plate take off link to?
All I have at the moment is the hose from the heater to the tap on the block and
Thermostat hose to radiator.
I’ve bought this hose but worried it’s the wrong one.
I know I need a metal connector from this pipe but not sure where to
Posted 13 June 2019 - 07:19 AM
I presume you mean head as there are no water take off on the block.
so you can bin the sandwich and just plumb as per standard Mini. so that hose is fine.
Posted 13 June 2019 - 07:30 AM
I read somewhere that the way an spi is plumbed in is the best way to keep the engine cool. Is that right? That’s why I thought I’d keep the sandwich plate
Posted 13 June 2019 - 07:33 AM
the best way is to take water from the head take off and have it always running through the heater.
so no sandwich.
basically the sandwich replaces the head take off. but the head take off helps keep 3 and 4 from getting too hot.
Posted 13 June 2019 - 09:15 AM
So the take off on the new bottom hose I’ve bought will link to the heater matrix?
Posted 13 June 2019 - 09:16 AM
Oh ok .so the tap thats on my turbo head has been drilled out and put on for the mini setup? So like you say I can do away with the sandwich plate. Great thank you.
yes but it is the return from the heater matrix. the one on the head is the feed.
Posted 13 June 2019 - 11:34 AM
