Engine in the mini is a metro turbo. I’ve put on a stabiliser (top righthand side) but the intake chamber is touching the bulk head.. do I need a longer fixed one? or do I need an adjustable one?
Im guessing the stabiliser I have is standard..
The fan has the smooth side facing the engine doesn’t it? But when I try That way it hits the breather.
Does it need a spacer between the pulley face and the fan?if so can I get longer bolts?
Few Queries..engine Stabiliser And Fan.
davecrook1
, Jun 14 2019 07:13 PM
5 replies to this topic
Posted 14 June 2019 - 07:13 PM
Posted 14 June 2019 - 07:40 PM
Ideally you need a 1990 onwards front subframe. You could try adjustable steadies
The fan will be marked engine side...
Edited by cal844, 14 June 2019 - 07:40 PM.
Posted 14 June 2019 - 07:55 PM
Yes you can use an extra spacer and longer bolts - or flatten the breather can.
Posted 14 June 2019 - 08:20 PM
Adjustable steady will be your friend.
Posted 14 June 2019 - 08:49 PM
Cheers fellas
Posted 14 June 2019 - 10:29 PM
You can get a timing cover with a flattened breather: https://www.minispar...|Back to search
