I mean the top hose is solid, so presume there's no water going through the thermostat even when boiling hot, but since I made that post, I'm not sure gauge is working correctly!
So I replaced my sticking Thermostat with one from Minimine, 82 degree one. I tested it before I fitted it, and it opens at 82, but not very far.
I took it for a run and it gets hotter than normal, and there's pressure in the top hose when I stop, which I believe must mean the water is not getting through the thermostat?
pressure in top hose ? What do you mean the whole system will pressureise
Second question, is the thermostat meant to completely open at 82, or whatever rating it is designed?
Not sure really, id guess it should start to open as to how much travel it has no idea. Also i have a "high flow" 6 blade metal fan your welcome to if you want to grab it from me. You will most likely need a spacer.
It will get hard. The WHOLE system including top hose and radiator pressurise which is why you never take the cap off a hot engine unless you want to get sprayed with boiling water. Increasing the pressure means water stay liquid to a higher tempreture. By releaving pressure ( opening the rad cap) the water on the block will flash to steam and expand spraying the water out.
Water at 150 Bar will stay liquid over 360C So increasing the pressure to the system to just over 1bar like the rad cap ( 15 psi) means it will stay liquid over 100C
Water in a mini rad will boil around 120C
Edited by phillrulz, 09 July 2019 - 05:48 PM.
