So in 6 years I'm on my 3rd thread-in auxiliary fan thermo switch C-ARA4443 the one in the car appears to have given out again. I mean it's a simple screw in 22mm x 1.5 with 2 spade connectors. So I spent a bunch of time looking for a different brand but most are listed by the make of car they fit not by temp, thread type, or connector. Anyone have a cross reference fit for a 2 spade connector, 22mm x 1.5, 92 degrees on 82 degrees off thermo switch? I think maybe a Volkswagen type fits but can't find all of the specs for them.
Problems With Fan Thermo Switch
Best Answer bikewiz , 19 June 2019 - 11:27 AM
Mahle do a good range of different on/off ranges, if you type "TSW" into the search box of this website:
https://catalog.mahl...u/product.xhtml
Be careful as it will be a combination of M14 and M22 fittings!
That's what I was looking for. From that list I found it cross references with a Saab switch which are readily available over here for $8.50/6.75 GBP
Thanks for that.
Go to the full post#1
Posted 18 June 2019 - 09:53 PM
Posted 19 June 2019 - 07:37 AM
I think I trawled through the ebay listed ones checking the rating. A pain but I got there in the end
That seems a long way to drop ?
I'm not sure what the original spec was but it seems the fan would be on forever, only my initial thought, as I say, not sure what they tend to be and I don't know how efficient your fan is.
I use a 95/90 with that same thread but I wouldn't do so in the bottom of the rad as per standard fitment, I think that's in the wrong place, mine's at the top of the engine tho I must say I never let it cut in, I always switch it on before that. It's just a safety net if I happen to not look at the ( Capilliary) guage.
Posted 19 June 2019 - 07:50 AM
Posted 19 June 2019 - 10:04 AM
Posted 19 June 2019 - 10:48 AM
My aux fan thermoswitch setup is a little bit different. I believe it is the mod they used in Japan, seeing as my car is a JDM, for older 998cc cars with aircon (later SPI uses the same Rover twist-type switch).
What they did was to cut the radiator bottom hose in half, fit a T-section there and fit a screwed-in thermoswitch. Mine, as fitted, was from a Honda, parts no: 37760-pb2-001 fitted to the 80s Honda Civic and also I believe early Rover 200s(?) and it switch on at 93 degree, switch off at 87. The beauty of this system is that you can adapt the switch to any of your liking, although most probably you'd need to fabricate your own connector.
Posted 19 June 2019 - 11:27 AM Best Answer
Thanks for that.
Edited by bikewiz, 19 June 2019 - 11:28 AM.
