The engine steady bar from DSN needs two holes in the block.. But my SPI does only show one hole!??
Has anybody an idea if one or two wholes is correct? My car is a LHD.
Posted 20 June 2019 - 12:46 PM
Posted 20 June 2019 - 01:27 PM
If it's this one: http://www.dsnclassi...ort-adjustable/
I'm sure it just uses the standard bolts on the clutch end of the block.
Do you have any photographs of your engine?
Posted 20 June 2019 - 06:28 PM
Posted 23 June 2019 - 09:39 AM
Thanks for your help. I have found the second missing hole. The pre-owner must have broken the longer bolt in the block and must have painted over the second hole so I could not see it.
I drilled the reminders out and mounted the adjustable engine steady. It is now all done and I am happy that the rattle stopped and the engine is now quiet.
I have never experienced such an "easy and invisible" thing with such an amount of work.
Edited by Alpenflitzer, 23 June 2019 - 09:44 AM.
