1992 Floor Panel Covering/soundproof
Posted 20 June 2019 - 04:44 PM
My son and I are restoring our first mini. It’s a1992 British open classic.
I have recently been cutting out the rot in the floor pan and in doing so I have removed the floor covering on the inside of the car in the places worked on.
This covering looks like a black tar that has gone solid. It must have done a good job because thankfully there isn’t to much rust. I used a wire brush fitting on an angle grinder to remove it
My question is What is the covering?
Is it still available to replace.
I have tried to include some images.
Thanks for your help in advance.
6DE9F22F-3520-4626-B2A4-B1DEBCE86D80.jpeg 44.22K 1 downloads
C44E9CDC-EF52-4412-83C6-F05A6154D838.jpeg 64.54K 1 downloads
71FC3BE4-011D-4611-BCB0-FD093940C170.jpeg 45.41K 1 downloads
Posted 21 June 2019 - 11:00 AM
It's applied as an anti-vibration paste rather than rust prevention coating, although it does do both.
I don't know if you will find the tar based products available anymore and today there are many better options.
Posted 21 June 2019 - 11:06 AM
Remove all of it if you have not done so. It weighs quite a bit so some weight saving done. Then buy something like Silentcoat or similar.
Lots of products out there.
Posted 21 June 2019 - 06:43 PM
Posted 23 June 2019 - 05:16 AM
Posted 23 June 2019 - 01:01 PM
This is the stuff I use. Flexible to apply (I used a heat gun to mold it into the floor pressings) and sets like the the original deadening
Posted 23 June 2019 - 05:03 PM
Did you forget a link or image Panky?
Posted 23 June 2019 - 10:11 PM
