How easy is it to install the heater take off valve, I have a SPI engine which I have rebuilt and is now 1293 Calver ST has done all the engine work along with a hif 44 conversion and Im trying to find the best option for the heater connection any ideas would help
Spi Cylinder Head
Posted 20 June 2019 - 06:08 PM
Posted 20 June 2019 - 06:42 PM
Phil.
Posted 20 June 2019 - 08:54 PM
Posted 20 June 2019 - 09:14 PM
What year of car? I will assume pre 90... if so the threads should be there for the small studs, just drill the large hole in the centre
He mentions SPI in title and post so I will assume it's 94-96
Edited by RooBoonix, 20 June 2019 - 09:15 PM.
Posted 21 June 2019 - 12:35 PM
Hi 93 SPI engine head is already fitted and torqued up by engine builder so wouldn't want to get any swarf in the water jacket or radiator ( threads are in for the valve but blanked off), just wondered if I can go from the two heaters hoses one hose to the heater valve that is floating second hose to manifold then to the sandwich plate take off and use a CLASSIC MINI - RADIATOR BOTTOM HOSE FOR 1275cc Minis with an HIF Carb - GRH1159 instead of trying to use the SPI bottom hose which has an extra take off
Edited by I hate Brian, 21 June 2019 - 12:40 PM.
