Hi everyone, I am new here and a new owner of a mini and I am absolutely in love!
The car is in great condition in and out but I've experienced some trouble these last days after something went wrong charging it up.
Last week I left the lights on and it drained the battery. I started charging it with the battery in the car with the minus connected to minus and the plus to the chassis as was recommended on this car. After a while i noticed some coming from the right hand side where there are two 35a fuses. I stopped the charging and took the battery out to charge instead. After the charge and the battery was in the car again the fuse for the horn (only the horn i think?) was burnt and got burnt as soon as I put a new one in. A couple days later I tried to put a new fuse in again and it worked for a day the got burt again. I decided to check it out later since only the horn seemed to be affected. (Worth mentioning the fuses I put in was 30a, not 35a as was in there before)
Yesterday the car suddenly started to shut off while driving but quickly started again a few times. I stopped by the side of the road and it would not start, not even a sound just the ignition light lit up. I waited a minute and it started fine and drove home with no problem except for the lights in the dash, headlights, high-beam and rear lights didn't work. Indicating lights and breaking light however work fine.
So, I have just checked the cables i can see and the few fuses I have found and it looks fine.
I am not sure where to look or what could have gone wrong, are these problems with the lights related to the engine shutting of yesterday? Could it be some short somewhere?
Please tell me if you need more info or pictures and I will supply you with what you need in order to help!
And for any help you can offer I am incredibly grateful and I look forward to exchanging knowledge, experiences and inspiration with you fellow mini owners!
------------------------------------------- Update 2 days later: -------------------------------------------
I've checked the ignition and light switches and found the following:
The ignition switch seemed to have a couple bad connections, not sure but I tried to get more cable in the connectors and tighten the screws. After this the sweet spot for ignition seemed to have gotten smaller and I have to slowly twist the key around to find it for ignition to happen. However, once it starts there is no problem. Drove around for a while, left it running a while, drove some more, no problems and didn't get as hot as before.
The light switch had three cables going in to it, one blue, one red and one brown.
The brown was connected to the one that seems to have gotten a bit hot... See image below.
I tried connecting the brown to the connector under it and my lights started working... Kind of.
The rear and front small lights works fine. However the only the right headlight works on the lower setting (daylight? Half-beam? English is a second language...) and when I turn on highbeam both work but not my extra lights that used to light up before.
Edited by TobbeH, 24 June 2019 - 05:50 PM.
