Correct Plumbing Yellow Tag
2 replies to this topic
#1 Mini_Problems_
Mini_Problems_
    Formally known as Cmontgomeryc
  • Just Joined
  • 46 posts
Posted 24 June 2019 - 12:15 PM
I am in the process of converting my servo brakes to non servo using yellow tag I have a 1991 mini city e. Before anyone says won't this invalidate you insurance, nope. Adrian flux didn't raise my premium nor did they cancel my policy. Would recommend .
I have found alot of information but I am unsure if this is for converting from black to yellow tag etc.
If facing the MC looking into the bonnet should the top connection of the mc go the the left hand side of fam7821. Cheers
Edited by Cmontgomeryc, 24 June 2019 - 12:15 PM.
#2 richmondclassicsnorthwales
  • 942 posts
Posted 24 June 2019 - 04:46 PM
Hi
The top pipe on the master with the 10mm union goes to the left union on the valve
The bottom with the 12mm union goes to the right on the valve
Hope this helps you on your way. I also make the pipes for this conversion. Link is below.
https://www.richmond...60732&id=728024
#3 Mini_Problems_
Mini_Problems_
  • Just Joined
  • 46 posts
Posted 24 June 2019 - 06:37 PM
Thank you for your reply, I have bought a yellow tag master cylinder with the pipe work attached I assume this will be correct
