Hi All,
I'm about to start tackling the front end and could do with some advice on which order to change the panels. Below is a list of what I'm changing the my current 'plan'
Inner wing R & L
Toe-board
Bulk head repair panel (below x member) L & R
outer wing L & R
Front panel
Scuttle.
I've current got the got the original panels fitted apart from the outer wings and front panel.
sooooo, I'm thinking
Cut out the old toe-board and replace, welding to the floor and bolted to the internal bracing (front sub points)
Remove the old inner wings (R&L) and scuttle.
repair the bulk head
weld the toeboard to bulkhead
fit the inner wing
Fit scuttle
fit front panel
fit outer wings
any suggestions / issues with the plan??
thanks
Chris
Chris
