Steering Boss
suspension electrical
4 replies to this topic
#1 Theo
Theo
    Starting My Mini Up
  • 4 posts
Posted 25 June 2019 - 10:19 PM
the steering boss (which lets you fit a custom steering wheels) that came on my car is wrong because when you do up to main bolt it pushes against the indicator auto switch off bit so I was hoping some one would know where I can get one that dose not do that
#2 nicklouse
  • 19,058 posts
Posted 26 June 2019 - 12:20 AM
it all depends.
year of car last ones had a different spline taper.
what wheel not all use the same bolt pattern.
Edited by nicklouse, 26 June 2019 - 12:28 AM.
#3 Spider
  • 15,848 posts
Posted 26 June 2019 - 03:04 AM
The Column has some adjustment in it.
If you slacken off the Clamp on it (the one near the dash), you'll get about 30 mm movement.
You'll probably need to drill the bolt head though as they are a 'security' shear head bolt.
#4 Theo
Theo
    Starting My Mini Up
  • 4 posts
Posted 26 June 2019 - 06:08 AM
I’ll try that thanks
And to be honest I don’t really care what wheel I use I just need it on the road
#5 Ethel
  • 26,795 posts
Posted 26 June 2019 - 01:24 PM
There were differences in the self cancelling mechanism over the years.
Have a look at the mechanism and the bottom of the boss to see if they can be mated together. It may be the wheel just needs turning relative to the boss so different holes line up and allow the boss to align with the indicators when the wheel's the right way up.
Also tagged with one or more of these keywords: suspension, electrical
