Spi A/c One More Time Around
Best Answer masslaw , 27 July 2019 - 01:25 AM
All is well again in my Mini world. A new thermostat solved the ac problem thanks to members of this group. Thanks to everyone who gave input. Much appreciated
Go to the full post#16
Posted 28 June 2019 - 07:13 PM
#17
Posted 29 June 2019 - 01:06 AM
Thanks. I'm working on it. Everyone has been a big help.
#18
Posted 29 June 2019 - 11:34 AM
There is also the possibility that the rotary temperature control has worn out over the years, so instead of telling the compressor to engage, it sends nothing. Or AC Thermostat failure is also very common.
#19
Posted 05 July 2019 - 05:59 PM
I've been able to locate anew rotrary switch and thermostat. I'll install them and see if that fixes things.
#20
Posted 27 July 2019 - 01:25 AM Best Answer
#21
Posted 27 July 2019 - 11:01 PM
#22
Posted 29 July 2019 - 11:08 AM
Where is the a/c thermostat located?
It will usually be located in the left-hand parcel shelf, above the aircon blower unit.
#23
Posted 30 July 2019 - 05:44 PM
It's behind the dash pocket on the passenger side.
#24
Posted 20 January 2020 - 11:19 PM
#25
Posted 21 January 2020 - 07:25 AM
#26
Posted 03 February 2020 - 12:49 AM
byWhere do you get the thermostat?
Got mines from japan. http://www.dinky.co.jp
Edited by kommander, 03 February 2020 - 12:51 AM.
#27
Posted 03 February 2020 - 04:01 AM
It is a Japanese import with the two wheel-dials for the ac. I believe it is all original. I cannot see, without dismantling, if there are any identifying marks on the compressor but anyway that seems to be working. Evidently I have an issue with power to the compressor. Do you think the wiring diagram from the 1997 diagram is correct for my system?
The fan switch on the 97 diagram is a 4 position unit. The 2 wheel switch Bobbins refers to is a variable resistor type. Try the 98 diagram
