Does This Manifold Gasket Look Ok?
14 replies to this topic
#1 slayerofcows
slayerofcows
  • 25 posts
Posted 03 July 2019 - 10:44 PM
Hi All,
Just received a new manifold gasket today from minispares. Was shipped in a jiffy and seems like it’s bent. Also the two faces seem to be separating in places.
Does this matter or does it all just squish in and make a seal regardless? Or should I be chasing for a replacement... don’t want to look like a fool if it’s fine like this!
Cheers! Alex
#2 nicklouse
  • 19,060 posts
Posted 03 July 2019 - 10:53 PM
I have used worse.
#3 slayerofcows
slayerofcows
  • 25 posts
Posted 03 July 2019 - 11:02 PM
Hah ok. I’m suspecting an air leak so just wanted to make sure I was eliminating a suspect.
I do have suspicions that it’s something else but I’m saving that for a different thread ‍♂
#4 Rorf
Rorf
  • 866 posts
Posted 04 July 2019 - 05:24 AM
I would not be happy with that gasket, minispares packers off loading damaged stock again!
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 04 July 2019 - 09:16 AM
Try fitting it with the damage to the top of the engine, that way if it does give issues you will know. I have used worse though
#6 andyapanel
andyapanel
  • 651 posts
Posted 04 July 2019 - 01:12 PM
I would not fit it
#7 slayerofcows
slayerofcows
  • 25 posts
Posted 04 July 2019 - 04:01 PM
ok, so bit of a split vote then.... think i'll contact them see if they agree it should be replaced
#8 nicklouse
  • 19,060 posts
Posted 04 July 2019 - 04:16 PM
There has been no mention if this is new or old. Did it leak with this one one?
#9 slayerofcows
slayerofcows
  • 25 posts
Posted 04 July 2019 - 06:12 PM
I’ve not fitted it yet. This is brand new from minispares. Figured I probably couldn’t return it after fitting it
#10 Dusky
Dusky
  • 5,322 posts
Posted 04 July 2019 - 06:25 PM
The aluminium inside is what really makes the seal, no problem at all to be honest.
#11 Boycie
Boycie
  • 1,978 posts
Posted 04 July 2019 - 08:43 PM
I'd use that. (just to confuse things further!)
#12 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 04 July 2019 - 09:17 PM
From experience of changing this gasket quite abit, fit the best type you can, so if you have any doubt..
Found the med & swiftune premium ones pretty good.
Edited by Midas Mk1, 04 July 2019 - 09:18 PM.
#13 Jamdog
Jamdog
  • 51 posts
  • Local Club: 998
Posted 04 July 2019 - 09:18 PM
It’s perfectly fine. They’re very easy to bend
#14 slayerofcows
slayerofcows
  • 25 posts
Posted 04 July 2019 - 09:41 PM
Ok thanks all. Advice very much appreciated! I’m just gonna use it, see how I get on then. Job for the weekend so probably wouldn’t get a replacement in time. If I have any suspicions later on with it then I’ll rip it out and just get a better one.
#15 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 05 July 2019 - 06:50 AM
As others have said, I too would use it and have used far worse.
