Another Lighting Issue - No Headlights Or Sidelights
12 replies to this topic
#1 Ollie36
Ollie36
  • 28 posts
Posted 05 July 2019 - 09:10 AM
Hi all,
Sorry if this has been covered before but can't find another topic with the exact same issue.
I have a 1994 (used to be a Mayfair, converted to Cooper but I don't think the wiring has been changed) and as I got into the car last night I went to turn the lights on as normal, however they didn't turn on, neither did the sidelights. The rear lights worked fine.  On the dash the high beam indicator is illuminated, but the stalk is in its correct position, again the high beam lights do not work.
This has occurred once before, I left the car for 12 hours and it worked fine the next day, however when I tested it today it was in the same state.
Any help or ideas would be much appreciated.
#2 cal844
cal844
  • 6,566 posts
  • Local Club: www.scottishmini.net
Posted 05 July 2019 - 09:53 AM
Change the switch, then look behind the speedo binnacle for 4 inline fuses, any melting they need changed. Also check the stalk for continuity
#3 Ollie36
Ollie36
  • 28 posts
Posted 09 July 2019 - 08:44 AM
Thanks, I've ordered a new switch so will start there and see how I get on.
#4 blacktulip
blacktulip
  • 5,758 posts
Posted 09 July 2019 - 09:26 AM
Have you checked the bullet connections behind the grille?
#5 Ollie36
Ollie36
  • 28 posts
Posted 18 July 2019 - 10:15 AM
Bullet connections all look ok, switch has been replaced, cabling looks ok. I'm starting to wonder if it could be an earthing issue? If so, would anyone be able to point me in the direction of where they are?
#6 cal844
cal844
  • 6,566 posts
Posted 18 July 2019 - 10:50 AM
The earth point is on the triangular strengthener at the bulkhead on the drivers side of a right hand drive car
#7 cal844
cal844
  • 6,566 posts
Posted 18 July 2019 - 11:08 AM
#8 luismx123
luismx123
  • 349 posts
Posted 18 July 2019 - 12:23 PM
as Cal said above. had the same issue once before. just had to tighten the screw holding the dim/dip box to the body and it worked.
#9 Ollie36
Ollie36
  • 28 posts
Posted 18 July 2019 - 12:39 PM
Thanks guys
#10 cal844
cal844
  • 6,566 posts
Posted 18 July 2019 - 06:05 PM
Also take a look behind the speedo binnacle for 4 inline fuses that control the lights. My 1994 built car and a spare loom both have these
#11 Ollie36
Ollie36
  • 28 posts
Posted Yesterday, 01:23 PM
Update: tightened the fuse box slightly, but no change. Also, now on the dash the full beam light only comes on when the main beam is selected on the switch, whereas before it was illuminated on both the side lights and main beam position. The rear lights have are also now not turning on where they were working fine before.
FURTHER EDIT:
with sidelights on I now have both sidelights working, however passengerside one is very dim, and rear passenger side is on but drivers side not
Edited by Ollie36, Yesterday, 01:48 PM.
#12 cal844
cal844
  • 6,566 posts
Posted Yesterday, 03:14 PM
FURTHER EDIT:
Sounds like you have a fuse out, remove the fuses one at a time, then try to rotate the ends, if they spin replace the fuse.
#13 Ollie36
Ollie36
  • 28 posts
Posted Yesterday, 03:33 PM
FURTHER EDIT:
Thanks, checked the fuses, they seem ok, the actual fuse box has seen better days so I am going to replace that. Just took out all the foam as well as have read that this can get wet and therefore corrode the fuse box
Mini Spares
