Outer Driveshaft Cv Joint Removal
8 replies to this topic
#1 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 06 July 2019 - 06:52 PM
Hi All
Got a busted cv joint here, got most of it off but i am left with the bug lump of metal on the end of the chaft that the ball bearings sat it. I've just busted my 3 leg puller, bend it, trying topull this thing off. Is there some sort of special tool to pull this off ?
Somthing like a horse shoe that you could put on the back and somehow pull againist the bit of driveshaft that is sticking out? Is there such a tool ?
Craig
#2 A-Cell
A-Cell
  • 1,610 posts
Posted 06 July 2019 - 06:57 PM
A drift and a hammer.
Don't be afraid to hit it.
Put the connecting bar in a vice if out of car.
#3 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 06 July 2019 - 07:44 PM
As A-cell mentions,
The easiest way to remove these is with a drift or old cold chisel or the like and a good sized hammer. If the driveshaft is off the car clamp it firmly in a vice and a couple of sharp whacks should remove it. The ball cage is retained by a circular clip which locates on both the driveshaft and the ball cage and the sharp hammer action should overcome the force needed for removal.
Cheers, Steve.
#4 KTS
KTS
  • 2,490 posts
Posted 06 July 2019 - 08:24 PM
..as above, but just make sure your driving against the CV inner and not the collar on the driveshaft itself
#5 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 07 July 2019 - 09:20 AM
Thanks Guys, its currently on the car and i would rather not remove it completly if possible, is there a circlip i should be removing ?
Should i be attaching this with the grinder and then split it open to remove it ?
Retaining collar on the driveshaft ? Is there an exploded view or something that i can see the component parts of this somewhere ?
Thanks again
Craig
#6 timmy850
timmy850
  • 3,616 posts
  • Local Club: MITG
Posted 07 July 2019 - 10:43 AM
The outboard end is on the left in this photo. The spring clip opens up inside the CV to stop it falling off. The retaining collar is the thicker ring. I put the driveshafts in the vice and gave them a really good wack with a drift and hammer
#7 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 10 July 2019 - 10:10 AM
Thanks for all the replies guys.
Craig
#8 andyapanel
andyapanel
  • 651 posts
Posted 10 July 2019 - 11:58 AM
I prefer a copper mallet.
#9 Rorf
Rorf
  • 866 posts
Posted 10 July 2019 - 12:20 PM
I would remove it from the car. If you have pot joints on the inner it will cost you a metal boot tie and some new cv grease. Put the shaft in a vice and cut the old cv inner off with an angle grinder.
