Hello all, just got my first mini and trying to fix an issue with sluggish acceleration on 2nd/3rd. its slow to pick up and then has a burst of speed. I've researched around and found mostly suggested adding oil to dashpot. I added some 3 in one motor oil to the dashpot which has now caused my throttle to stick. I have to hook my foot on the pedal and bring it back up to keep it from revving high. Also when manually pulling the throttle cable it feels like its catching at the end, I have not messed with the cable at all though and did not have an issue until adding the oil. I would appreciate any suggestions on fixing the flat spots and how to remedy this stuck throttle.
Is there anyway to drain out some dashpot oil?
