1275Cc Only 3 Gears!
8 replies to this topic
#1 Poppet2
Poppet2
  • 139 posts
Posted 09 July 2019 - 01:29 PM
It's an automatic, but does that make it less powerful then if it was a 4 or 5 gear manual engine?
#2 MikeRotherham
MikeRotherham
  • 1,032 posts
Posted 09 July 2019 - 02:00 PM
Is your car faulty? Does it only appear to have 3 gears?
The mini automatic always had 4 gears when it was introduced which made it a step up from its contemporaries who only had 3.
With regard to the power output, some is lost due to the torque converter when compared to the manual.
#3 Poppet2
Poppet2
  • 139 posts
Posted 09 July 2019 - 04:11 PM
Nope, both the 84 & 92 automatic mini's had 3 gears. I have the photo of the 92 gear lever & box to show you, but I don't know how to upload photos on here. The staple clip sign to upload photos isn't on my screen.
#4 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 09 July 2019 - 05:57 PM
ALL mini automatics ARE 4 speed. I've driven one of each of the mk(1-4) and all have 4 gears
To upload pictures I use IMGUR. Upload the image there(You'll need to make an account.... very easy takes minutes)
Then once you have the image uploaded you copy and paste the code to your post on here
Edited by cal844, 09 July 2019 - 06:00 PM.
#5 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 09 July 2019 - 06:09 PM
I hate to state the obvious but I believe the gear leaver states
1
2
3
D
As I understand it positions 1-3 put the gear box in that gear, position D (drive) is in fully automatic and you will get gears 1 through 4.
Position D is effectively 4.
I feel the need to point out I have never driven an auto mini, but this is my understanding
#6 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 09 July 2019 - 06:16 PM
1
2
3
D
You have described it perfectly ?
#7 mab01uk
mab01uk
  • 13,092 posts
Prototype Mini Automatic 1962
"The design itself put all known hydraulic boxes in the shade and to make the most of the 850cc engine's meagre output, gave four speeds as against the three of other automatics current at the time."
More here:-
http://www.theminifo...automatic-1962/
Edited by mab01uk, 09 July 2019 - 06:17 PM.
#8 Spider
  • 15,881 posts
Posted 09 July 2019 - 06:48 PM
This is a snippet from the 1978 to 1989 Rover Factory Workshop Manual
I think it might be easy to think or suspect they have only 3 gears due to the layout of the shifter pattern.
As the other guys have said, all Mini Auto Boxes from their introduction to the end of production had 4 forward gears.
#9 Poppet2
Poppet2
  • 139 posts
Posted 09 July 2019 - 10:07 PM
Yes, that's it, thanks everyone for your explanations.
However, this is the layout for the 1984 mini. It doesn't have a Park P. Can I transfer to a 92 mini that in addition has a Park P on the gearbox? Or will this create problems?
