Yet Another Spi Spot Lamp Wiring Question
8 replies to this topic
#1 rossul.burn
rossul.burn
  • 233 posts
Posted 09 July 2019 - 06:16 PM
I've been looking all over the forum and cannot find an answer to my question.
I've got a 95 SPI mayfair and from what i've read the SPI's came with wiring for spot lamps. Correct?
Well I hope it is as I have been looking in the engine bay and on the spare loom I have for these elusive connectors. There is nothing behind the grill in terms of connectors but on the wiring to the headlights I have noticed that on both sides just next to the grommet going through the inner wing there is the White and Blue wire which is for highbeams. On the main loom there is a double female connector, one is occupied by the high beam and the other is spare.
Is this where I would connect the spot lamps too? There is a lot of spare wire on the headlight cable that has been folded over but the female connectors are on the loom and cannot be moved.
Ross
#2 phillrulz
phillrulz
  • 547 posts
Posted 09 July 2019 - 06:18 PM
The SPI i have has had the loom butcchered for spots so im unsure about that.
#3 viz139
viz139
  • 236 posts
  • Local Club: Irish Mini Owners Club
Posted 09 July 2019 - 06:49 PM
To fit the spots on an SPi there is an additional loom that joins to the main loom.  If I remember correct.
Blue /white joins to the bullet female on RH side.
Above the servo you will find a brown wire with a female spade.
And the black joins the earths on the RH wing.
The extra loom has a fuse and relay ( fits beside horn relay) and wires to the front grille with two connectors for spots.
I haven't seen the Rover loom for sale anywhere but it is something that could be easily removed from a scrapped car.
#4 hunterg30
hunterg30
  • 307 posts
Posted 09 July 2019 - 06:50 PM
Don't think all spi's had the extra connections for spots/ fogs my 95 never had them
#5 rossul.burn
rossul.burn
  • 233 posts
Posted 09 July 2019 - 06:58 PM
So is this the type of loom I am after?
https://www.ebay.co....tm/232308017988
#6 cal844
cal844
  • 6,853 posts
  • Local Club: TFMOC
My 1994 sprite and 1994 Italian job looms both have additional fog light wires to the front and rear(in the boot I think it's for LHD cars) high beam wiring can be connected using the extra connection on the standard loon connections behind the grille
#7 ukcooper
ukcooper
  • 1,625 posts
Posted 09 July 2019 - 07:34 PM
my 95 spi did not, and im thinking if they did it only the two outsise ones
#8 rossul.burn
rossul.burn
  • 233 posts
Posted 09 July 2019 - 07:56 PM
Well I've ordered some spot lamps and the wiring kit to get them sorted. Thanks for all the help
#9 viz139
viz139
  • 236 posts
Posted 10 July 2019 - 07:34 PM
Yes The Kit in the link above looks like it does the same job.
Mini Spares
