The front end of my mini is sitting about 3inches + higher than the rear. My hi/Los are set to the lowest they can be. All the suspension is brand new so is it because the cones need bedding in or will the adjustable arms bring it down?
Cheers se
i'm with Bobbins on this one - 3" is a lot settle, and with hi-los wound down to the lowest they can be i'd have thought the front would be pretty much on the bump stops even with new cones. what's the gap between tyre and arch on the back vs the front ?
one thing that might be worth checking is that the cones are correctly seated into the subframe towers
