Does Anyone Use A Separate Battery For Timing Light.
16 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 11 July 2019 - 02:39 PM
I was thinking of getting a small 12v battery for things like timing light and testing. What do people use?
#2 whistler
whistler
  • 1,897 posts
Posted 11 July 2019 - 04:02 PM
Old 12v mini battery
#3 GraemeC
GraemeC
  • 7,473 posts
Posted 11 July 2019 - 05:32 PM
I don't use a separate one - what do you think the advantage would be?
#4 nicklouse
  • 19,060 posts
Posted 11 July 2019 - 11:37 PM
Only useful if you can’t access a 12v supply on the front of the car. Not an issue on most Minis.
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 July 2019 - 09:39 AM
Whilst it's not impossible to get to my battery, it is a bit awkward to get the clips on as it's in the wing.
I've ended up buying a small 12v 7amp battery from screwfix.
Attached File  20190712_103621_resized.jpg   27.46K   0 downloads
Edited by HUBBA.HUBBA, 12 July 2019 - 09:39 AM.
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 July 2019 - 09:42 AM
Like off the starter supply?
#7 GraemeC
GraemeC
  • 7,473 posts
Posted 12 July 2019 - 12:47 PM
Starter solenoid.
I think in your position I would install a heavy duty power point in the engine bay that could be used for this and to connect jump pleads should the need arise.
#8 GraemeC
GraemeC
  • 7,473 posts
Posted 12 July 2019 - 03:03 PM
Something like this:
http://www.vehicle-w...bution-post-red
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 July 2019 - 03:40 PM
I really like that idea
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 July 2019 - 03:41 PM
these look good
https://www.12voltpl...t-kit-350a.html
#11 GraemeC
GraemeC
  • 7,473 posts
Posted 12 July 2019 - 03:53 PM
Yes, they'd work.
Being through panel may give you more options with how you run the power to them, but could also give you headaches with ensuring they're insulated on the other side.
#12 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 14 August 2019 - 07:27 PM
I've ordered them now. While I'm waiting for them to arrive, just wondered if you have to connect direct to the battery or if I could connect + to the starter and the - to the body. I would like to use them to jump start the car as well.
#13 nicklouse
  • 19,060 posts
Posted 14 August 2019 - 09:19 PM
Earth one out body or engine. And the live one onto the starter solenoid live feed.
Then you have short runs and power where you want at the front. Could also be used to power a winch.
#14 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 August 2019 - 06:23 PM
You're a mind reader, I fancy a little winch on the front. The earth one - direct onto the chassis frame?
#15 nicklouse
  • 19,060 posts
Posted 15 August 2019 - 08:14 PM
Makes little difference but using the existing engine earth strap position has some merit.
