New Timing Gear Tight On Crank?
6 replies to this topic
#1 dougie1142
dougie1142
  • 500 posts
  • Local Club: I.M.O.G
Posted 13 July 2019 - 11:16 AM
Hi all.
This may have been asked before, but I recently purchased a duplex set for my 1330. The gear fitting onto the crank is very tight. I've tried using some grinding paste on the mating surface to smooth it a little bit it's still very tight. Is this common and I need to keep going, or is there something else I should be doing?
Thanks in advance.
#2 imack
imack
  • 2,382 posts
Posted 13 July 2019 - 01:10 PM
My Kent Cams vernier duplex is pretty tight on the crank, not mega tight, just too tight to fit by hand. Needs tapping on and the use of a puller or some careful levering to remove.
#3 Ethel
  • 26,810 posts
Posted 13 July 2019 - 01:18 PM
Try it without the woodruff and have a look at the keyways for burrs or bruising. Also the shoulders of the machined faces might want breaking with a touch of chamfering.
#4 mini13
mini13
  • 3,811 posts
Posted 13 July 2019 - 04:25 PM
I found emery works better, as above chamfer the edges with a needle file, also from where you've pasted it you should be able to see any high spots.
#5 Rorf
Rorf
  • 866 posts
Posted 13 July 2019 - 04:44 PM
Use emery tape, the gear must slide on without any force. Same applies to the gear on the cam shaft.
#6 dougie1142
dougie1142
  • 500 posts
Posted 13 July 2019 - 06:02 PM
Cheers guys, that's tomorrows task sorted then. I'll give each of the above a go
#7 Spider
  • 15,870 posts
Posted 13 July 2019 - 06:03 PM
As the other guys have suggested in regard to the emery - you don't want to reduce the crank nose size.
Many are too tight out of the box, I like to get them a firm fit, that's just too tight to move with the fingers, but only just.
