I am converting my Elf to a 2 speed wiper motor but am struggling a bit with the wiring.
The motor has a 5 terminal connector with the wires as follows:-
1= earth (black)
2= park (brown)
3= Fast speed (blue)
4=live feed (green)
5=slow speed (red)
The switch I have is a Lucas switch marked as 35927 P94317
There are 6 spade connectors on the rear numbered 1-8 however locations 3 & 5 do not have any terminals.
I’m struggling trying to sus out which wire goes to which terminal on the switch. I realise one terminal on the switch should be connected to an ignition switched live, but am not sure which terminal this should go to. Also wire 4 on the motor, where does this feed come from.
Any advice would be much appreciated
Wiper Wiring
DUF2
, Jul 15 2019 05:20 PM
No replies to this topic
