Check what the compression readings on all four cylinders when spun over on the start motor, all four plugs out throttle held wide open.. Also spin it over on the starter and spray WD40 on the manifold gasket area, you may have an inlet manifold gasket leak esp if not using a stock manifolds
18 replies to this topic
#16
Posted 18 July 2019 - 10:51 AM
#17
Posted 19 July 2019 - 11:01 PM
UPDATE :
So it was timing after all.
Now the mini had started but it wont idle down as in it will only run if the choke is completely open
This HIF 38 has no mixture screw just a fast idle adjustment
#18
Posted 20 July 2019 - 06:23 AM
UPDATE :
They have. On the drivers side of the carb. Google it.
#19
Posted 21 July 2019 - 08:52 PM
Got it sorted and done idles well thank you all for your help much appreciated
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
