Bore To Piston Clearance
6 replies to this topic
#1 Spackaveli32
Spackaveli32
  • 34 posts
Posted 17 July 2019 - 09:57 PM
Team Mini,
I am having a hard time determining the bore to piston clearance . I tried researching on the forums here, I tried emailing the company (no reply back), and I have tried searching the Internet with no luck. Can somebody please help me determine the clearance. Please see picture for details. Thanks again for the help.
Edited by Spackaveli32, 17 July 2019 - 09:59 PM.
#2 Spider
  • 13,888 posts
Posted 18 July 2019 - 05:31 AM
Measured at the bottom of the skirt 0.0004" (4 tenths of 1 thou) to 0.0014" (one point four thou).
I'd suggest running to the upper figure.
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,654 posts
Posted 18 July 2019 - 06:06 AM
I fit these at 0.0025".
Ac
#4 Spackaveli32
Spackaveli32
  • 34 posts
Posted 18 July 2019 - 09:48 AM
Thank you AC and Moke!
#5 Spackaveli32
Spackaveli32
  • 34 posts
Posted 21 July 2019 - 02:51 AM
Does this sound right. I was told by MAR Motorspot the piston to bore clearance for this part is 0.035mm not .0035. Seems a little high. Thanks in advance.
Edited by Spackaveli32, 21 July 2019 - 02:51 AM.
#6 Spider
  • 13,888 posts
Posted 21 July 2019 - 03:29 AM
That works out at 0.00137".
Short answer is yes.
These pistons are as OEM (same brand and type), the range of figures I gave were from the factory manual and quite in line with this figure.
#7 Spackaveli32
Spackaveli32
  • 34 posts
Posted 21 July 2019 - 03:58 AM
Moke, thank you!
