Hello
I intend to take my engine out
(Get it resprayed and do some work myself with engine out)
Never taken out
It's a 1989 mini mayfair 998cc
Anyway my question is
Can I move the car about with engine out
By pushing it (maybe a silly question )
Engine Removal
cristiano1968
, Jul 17 2019 11:22 PM
8 replies to this topic
Posted 17 July 2019 - 11:22 PM
Posted 17 July 2019 - 11:56 PM
Sure. As long as you reattach the ball joints.
Posted 18 July 2019 - 05:24 AM
Pedal Car
Posted 18 July 2019 - 06:39 PM
☺?ok
Posted 18 July 2019 - 06:44 PM
You'll need to refit the balljoints, then depending on if you split the pot joint or remove the pot joint complete you'll need rubber gloves to keep the ball bearings clean and safe.
Posted 20 July 2019 - 11:11 AM
We just pulled and installed an engine in a 1989 Mini 35 Anniversary. A search here will help. I posted quite a few pictures. You’ll need to remove the brake boost, carb and manifold out of the way. Alternator also as it’s a tight squeeze.
Posted 20 July 2019 - 12:23 PM
Brake booster just needs loosened from the mounting
Posted 21 July 2019 - 09:50 PM
Ok I'm nearly there .
So far taken out carb/air filter.brake servo .
Starter motor .alternator.brake fluid tank.
Radiator.heater hoses . (Few nuts and bolts really hard to get off?.
Hopefully get it out next week.
Found a friend of a friend who's lending me a crane.
Posted 21 July 2019 - 10:25 PM
Good for you!! Smart way to go and great to have friends with engine trolley!!
