So I replaced my throw out bearing and I'm ready to reinstall everything. Those bottom two bolts were nightmares to get out and I'm not looking forward to putting them back in. So much so that I'm thinking of leaving them off. Good idea? Bad Idea? Why or why not? Thanks for the advice.
Clutch Cover Bolts
Posted 20 July 2019 - 11:18 PM
Posted 20 July 2019 - 11:22 PM
Posted 21 July 2019 - 12:35 AM
The one that's around at about 8 O'clock I always leave out, it's almost at the back and the Subframe is just in the wrong / right place to make that one rather slow.
All the others are a breeze.
If the ones at the bottom are giving grief, jack the engine up further.
Posted 21 July 2019 - 12:37 AM
Yeah, that one was the worst.
Posted 21 July 2019 - 06:21 AM
Posted 21 July 2019 - 08:41 PM
Thanks guys. I think I may leave the worst offender off (the one at about 8 o'clock, as moke spider described it). Thanks for the advice as always.
Posted 21 July 2019 - 09:22 PM
I left one out personally, due to difficulty and it was so tight before i was extremely close to rounding it, the spanner was opening on it!
Posted 22 July 2019 - 07:43 AM
I cut slots into the holes for those two bolts on my clutch covers and use washers on the bolt heads to spread the load. That way you can wind the bolts most of the way by hand in before fitting the cover and then just slide it into place and tighten the bolts up the last few turns.
Posted 22 July 2019 - 10:37 AM
Clever idea.
I brazed a speedometer cable on to a cut down 1/4" drive socket, with a 5/16" nut on the other end.
Worked quite well, but it needed someone underneath to hold the bit of socket on the bolt.
Posted 22 July 2019 - 11:03 AM
Just put the engine on the work bench, much easier
Posted 22 July 2019 - 11:27 AM
I put them all back in, but I "copper slip" them and run them in the threads with the Wok still off so I know I can hand tighten them nice and easily the full length of the thread. Then when you do install the Wok you know you can hand tighten them easily then just a nip up with the spanner, they do not need to be mega tight. If you think about the leverage, the "bottom" bolts are pushed towards the engine by the clutch lever action, there is nothing trying to pull the bolts outwards (unlike the top ones).
Posted 22 July 2019 - 11:32 AM
Just put the engine on the work bench, much easier :DWell
That doesn't help at all.
It just annoys the wife, having to hold up the rest of the car.
Posted 22 July 2019 - 11:34 AM
Exactly. That is why cutting a slot is such a neat idea.
Edited by DeadSquare, 22 July 2019 - 11:36 AM.
Posted 22 July 2019 - 12:07 PM
You are right its just my OCD.. I hate seeing bolts / washers etc missing as I then wonder what else might be missing or I might have forgotten to put back. I started to put my clutch back in my pickup yesterday and it took ages.. checking .. double checking.. making sure I have not "forgotten" anything... I checked the Primary Gear end float a good 30 times and that Primary gear oil seal was treated like a King before and during installation
Posted 22 July 2019 - 01:30 PM
BMC sent out replacement primary gears with a a protective plastic sleeve over the oil seal surface.
Lightly greased, this was easily pushed through the oil seal, and of course, slipped perfectly over the primary gear.
