Am I able to use a 12G940, 11 stud Cooper S head on a 1275 block that hasn't been drilled for the additional two fasteners?
Cylinder Head Use
Posted 23 July 2019 - 02:51 AM
Posted 23 July 2019 - 02:54 AM
But I have seen one leak out of the thermostat side but that may have been a gasket issue.
Posted 23 July 2019 - 04:43 AM
Posted 23 July 2019 - 05:25 AM
Why not drill and tap the two additional holes, easier enough. Ensure you use a good quality head gasket and do not over torque the nuts and two bolts.
Posted 23 July 2019 - 07:12 AM
You should be able to do this fit up without issue.
Posted 23 July 2019 - 12:36 PM
You will not as every head is different. It depends on who did it. If you want to know you will have to have the two heads tested back to back.It’s my understanding that the two fasteners were to help with the higher compression of the original S engine but if I’m already higher at 10.5:1 using a 9 stud head I think it should be fine. I haven’t been able to find a flow comparison test between the S head and a more contemporary performance cylinder head.
As to if the two extra fasteners do anything useful is open to debate.
Posted 23 July 2019 - 02:14 PM
A well modified head should outflow a standard S head by an absolute mile.
Phil.
