Mini 1275 Not Starting After Mini-Service
14 replies to this topic
#1 zace66
zace66
  • 27 posts
Posted 03 August 2019 - 09:36 PM
So Tom has serviced the mini - oil filter change & oil, new plugs and rotor arm to start with,
It was running before, but now the engine refuses to fire into life.  We have checked the order of the cables, the fact that each of the plus IS sparking - they are.
So what else could be wrong?
I will add some pics in the morning - it's a tad late now, but this is bothering us (And tomorrow is the Blackpool car show AND the Lytham classic car show!)
There are all sorts of odd cables in that engine bay that I cannot identify - there is one from the area of the distributor up to the right of the engine bay - i think it is supposed to go into a T junction but then I have no idea where that cable/tube goes, all I know is that its shattered but has been for a long time.
I cant smell excess fule and nothing is spilling inot the engine bay.
#2 mk1leg
mk1leg
  • 9,341 posts
Posted 03 August 2019 - 10:03 PM
check dizzy cap and see if tabs inside are not corroded. check vac pipe is connected, condenser earth still attached, plugs leads in correct order 1-3-4-2 in anticlockwise order with No: 1 lead pointing to piston 1
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 03 August 2019 - 10:04 PM
There are plenty of things it could be...
Was the dizzy moved or taken out ?
The cable / pipe could be the vacuum advance pipe which should run from the dizzy to the carb
Are the plugs the right type / grade, have they been gapped
What model are we looking at ?  electronic ignition ?
#4 zace66
zace66
  • 27 posts
Posted 03 August 2019 - 10:11 PM
dizzy cap replaced - plugs checked and back in correct order
vacuum advance pipe - if that wasnt connected would it not start ?
#5 mpialan
mpialan
  • 100 posts
Posted 04 August 2019 - 07:49 AM
You say you cannot smell excess fuel. Are you getting fuel at all?
#6 absx2
absx2
  • 819 posts
Posted 04 August 2019 - 12:04 PM
Try the original rotor arm as some new ones fail straight to earth immediately and others 2 miles down the road so its worth a go even though you have sparks .
Edited by absx2, 04 August 2019 - 12:08 PM.
#7 zace66
zace66
  • 27 posts
Posted 04 August 2019 - 09:24 PM
So we put old dizzy cap and rotor arm back on.... not starting.
Alas accelerator cable snapped now. Sigh.
Fuel should be ok.... not touched that system as far a I know....
#8 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 04 August 2019 - 09:37 PM
The accelerator cable being snapped won't prevent the car from starting and running whilst on choke.
Get yourself to a bicycle repair shop for a universal rear gear cable, you'll need to cut it at the carb end but it will be perfect for what you need. I've used the gear cable as an accelerator cable for 6 years with no issues, all 3 of my minis have them to be honest. I've never paid more than £5 For one either, a cheap fix
#9 zace66
zace66
  • 27 posts
Posted 05 August 2019 - 09:41 PM
ok - latest in the saga.
Open the carb drop in some fuel.... full choke... it fires up!
No accelerator.. so then just dies after a few seconds.
OK I know we can rev it by hand ... not got that fat yet - need to learn WHAT to push/pull and how safe....
BUT would it be the fuel filter that needs looking at or the fuel pump ?
How to test/check either?
#10 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 05 August 2019 - 09:42 PM
I'd say pump first as that's most obvious
#11 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 05 August 2019 - 09:43 PM
I'd say pump first as that's most obvious you simply take the supply line off at the float bowl, put it in a jar, start the motor and see what happens
#12 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 06 August 2019 - 12:56 PM
It does sound like a fuel issue,
If the vac advance is off, that will lean the mixture at tickover and alter the timing to make it tickeover like a pig on beans
#13 zace66
zace66
  • 27 posts
Posted 06 August 2019 - 11:14 PM
Well Tom put the vacuum advance/retard pipe from the diz to the carb tonight - it still doesnt fire up
Cheers Cal ... er..... taking supply line off float bowl and into a jar.....
Hmm, does that mean take the line that goes into the carb from the fuel tank off - i presume it must split to put it inot a jar?  jar of fuel? or do i need to the find a bit of pipe to put into a jar of fuel into the carb OR if it just proving thast the carb is sending fule inot the engine and just an empty jar?
wow im a noob..
#14 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 07 August 2019 - 08:56 AM
wow im a noob..
You remove the fuel line from the tank from the top of the float bowl, position a clean, empty jar so that you can catch the fuel then try to start the engine.
You are checking that the fuel pump is working
#15 zace66
zace66
  • 27 posts
Posted 08 August 2019 - 09:42 PM
Ah cool.... will this make a sucking sound etc?
