Vented Cap - Mot Issue?
Posted 04 August 2019 - 06:35 PM
Posted 04 August 2019 - 07:33 PM
Posted 04 August 2019 - 08:47 PM
Posted 04 August 2019 - 08:56 PM
My pickup has a drilled vented fuel cap - it came with it. I am not sure it needs a vented cap but that’s another issue. It’s going for MOT Tuesday and last time someone told me it would fail and lent me a cap - this time I have no spare. Is a drilled vented cap an MOT failure on a 1979 mini 95 with an K1100 engine? TIA for your advice.
K1100 engine, or K110 head on an A series block ?
Posted 05 August 2019 - 07:19 AM
Totally agree with Ethel, it needs a vented cap, but how were the original van/estate caps vented, I don't remember there being a visible hole, they must have vented to the under side of the cap outside the filler neck.
Yes they vent to the underside.
Posted 05 August 2019 - 11:16 AM
Is a drilled vented cap an MOT failure.
Sounds like it. But no pics means we only see what is in our head.
Posted 05 August 2019 - 01:45 PM
Sounds like it. But no pics means we only see what is in our head.Is a drilled vented cap an MOT failure.
Will get one later. Imagine a normal cap with two small holes drilled all the way through from the face to the back.
Posted 05 August 2019 - 01:47 PM
k1100 head on A series block
Posted 05 August 2019 - 03:58 PM
You can never fail on anything that was legal when your car was made. I'm not a tester but I think the filler cap seal was added for visual inspection a few years back - that's entirely different to how the tank vents.
Inspection:
4. A fuel tank cap/filler neck sealing device:
a. missing
b. does not fasten/close securely:
• by a positive means, and
• such that pressure is not maintained on the sealing arrangement
c. sealing washer torn, deteriorated or missing, or a mounting flange/sealing method defective such that the leakage of fuel is possible
Reasons for failure:
a. missing
Source: http://www.ukmot.com...7.2/Fuel-System
So the cap must seal on the filler neck, even if petrol can pee out of a vent hole in cap if you manage to flip your car on its head.
Posted 05 August 2019 - 05:04 PM
That will be a fail if seen.
Posted 05 August 2019 - 06:41 PM
Posted 05 August 2019 - 07:37 PM
Interesting. I’ll let you know how it goes and I’ve got a local lad who can whip a cap down if it fails.
Just get the correct vented type. That will be fine. It is the modifications with drill that will fail it. IF SEEN.
Posted 05 August 2019 - 07:59 PM
Stick a label on the cap (over the hole)
NO UNLEADED PETROL
Posted 06 August 2019 - 06:48 PM
