Hi all,
was going to try and MOT the 998 mini this week so put the fuel system in and filled up. Started well enough but boy it is running rough.
Red light on dash wont go out so think its not charging but that's ok for now, 50psi idle revs up to 65psi on oil pressure
it sounds like it is struggling to breathe, but sounded the same with the air filter out. Cant stab the throttle or it nearly dies, have to build up the revs a bit more slowly
fresh fuel, tried moving the distributer about to no avail, idles fine but wont rev above 4000rpm and takes a couple of seconds to get to that.
points and rotor new although been in the car for a few years.
anything I can try before I give in and send it to the garage??
just in case, are there any classic garages near warrington??
Graham
Edited by grahama, 05 August 2019 - 04:38 PM.
