The engine I have just reinstalled is not firing on #2.
No missfire before I pulled it out ( pulled it due to a differential issues )
When I pull the wire off # 2 there is no change in engine rev.
I checked compression and have ~130lb on all four.
I have swapped plugs and swapped ignition wires with no change.
When I hold the lead to the plug...I can see good spark.
Wires are on correctly. #1 at aprox 2 o'clock, then #2 then #4 then #3 ( edit: clockwise from in front )
Edited by Spitz, 05 August 2019 - 09:40 PM.
